Just been having a further play with the pixel mapping effects layer, as I'm about to use it on a large project over the next few months.
I'm not sure if this a bug or I'm just being daft so thought I'd throw it out there.
Using a Virtual Effects Layer (both V1 and 1.1) and just using the pixel map preview, (I won't get the rig for a week or 2) all the effects, except the perlin noise, don't appear to work on 'Play loop forward'. When i say doesn't work it does but more on a 'Play once forward' sort of thing. Basically if i put the effect into 'Play loop backwoods' it will work, and for however long i leave it running in reverse, I can then run it for the same amount of time forward but then it stop's!
Is there something I'm missing?
This is using an off-line editor on a Mac running version 1.9.12
Any help greatly apreciated
Stacy
