Need to have COLORKEY Mover Miniwash Quad 4 RGBW moving head light added to library. Thank you.
This profile will soon be available on our website as ColorSource Console v2.5 - 3.0 Library Update 15.5.1.
The latest version of Library is always available here: ColorSource Consoles Software toward the bottom (under "Console Library Patches").
I guess I should note it's only compatible with ColorSource Console versions 2.5 - 3; not compatible with v1.0.2, if that's the version you're running.
Matt, thanks for the update. Currently on 3.0.0.33 and library 15.44. Followed your link and found the directory that has 15.5.1 in it. Directory I had been in the other day has loads ColorSource console and offline software, but no library files.
