To move a tab around, select it (easiest is to press [TAB] until the right one is selected), and then hold down the [TAB] key and press the right or left arrow keys.
Regarding your urgent issues, please contact ETC Technical Services directly, preferably by telephone.
Forums are generally not the best place to discuss showstopping or otherwise urgent issues - posts can easily get crossed over (as has apparently happened several times above), and it can take several hours to get a response from the right person.
There are several things we can offer, but it's best to chat to a real person to decide which route is the best for you.
Hi Robert,
I am terribly sorry for the problems you are having. Richard is right though, having someone on the phone,
will work much better.
Please call ETC Tech Services again, - better now during office hours, - and they will help you get
your console working again!
Please call 608/831-4116, or toll-free in the U.S. at 800/688-4116.
Hi Robert,
Technical Services should be able to help you if you give them a call today. Also, if you can send a copy of your latest showfile to congo@etcconnect.com, we can take a look into the problems you've been encountering.
Stu
Hi this is Justin, Roberts Assistant designer. If there is anything else you need I am standing by until the end of tonight. Thanks
