Channel Layout
Hi all
I use the Cobalt offline to do a channel layout of a show that has some RGB led bars that uses 48ch. I use the RGB pixel layout for those channels. The problem is when I load the play on a Congo Jr with Cobalt 7.3.1 and open the Channel Layout on the Live tab all of those RGB pixel don´t have any number. Instead of 101.1 it appears a 0 and the 0 is on every RGB pixel. I make again the layout on the Congo jr save the play to USB and open the play again on the Cobalt offline on a PC. This time I've got on those RGB pixel numbers like 1137 until 1152 on the first led bar so I've got to do everything again.
The question is it's normal this change of channels numbers between diferents consoles running the same software?????
When I try this channel layout on the V8 beta those channels are also completely different.
Pedro Alves
