Update palette problem?
We have some issue with "update palette". We use latest Cobalt 8 rev 100
We set pan to 40 and tilt to 55 and record "All Palette 15". We save this into a cue 1 and make some more cues. Now we go back to cue 1 and move tilt to 60 and press "Update palette" and push [Modify] on popupscreen. I change my pan and tilt and press: "664 CH 15 Palette" to see if we have the right position, everything works fine.
I press "SAVE" and "save with revision". I clear everything to a empty consolle and download my play again. Now pan is set to 40 and tilt to... 55. Not 60.
If i change my "15 all palette" to pan 40 and tilt 60, press "15 Record+Palette" > merge with existing and save my file and restart consolles it´s no problem.
What is the magic trick?
