ColorSource 40AV - Can you renumber all cues back to whole numbers?
Is it possible to renumber an entire shows cues back to whole numbers?
I have a show where I used up all point numbers between whole numbers. In other boards I've used there is usually a renumber function, where it will go down through your cue list and renumber everything back to whole numbers again. Then you can go back manually and order it the way you want.
Any help appreciated,
Gerry
