Hello all -
ColorSource v1.1.1 is now available here for ColorSource and ColorSource AV consoles. At that link, you can find the software, release notes, PDF user manuals in English, French, German and Spanish and a rereleased version of the ColorSource Edit applicaion, which is now known as ColorSource Personality Editor to more clearly indicate what it does.
This release includes a number of small tweaks and fixes, as well as a new cue/sequence step editing function and new captured channel behavior.
The new edit function clarifies how the Edit Cue and Edit Step functions work. In each of these screens, labels and times can be freely edited as before, and we've added a new button that will solo out all other playback from the stage to facilitate live editing of the cue or sequence step's contents. Once the cue or step has been stored and this mode exited, playback will return to normal.
In previous versions the ColorSource consoles could not hold a manual level across playback actions. The channel would be automatically released to playback. In this version, selected channels with manual intensity values will hold those intensity values until you deselect the channel (in which case the next playback action takes over from the manually set level) or until you clear channels, which will deselect the channel and clear the manual level at the same time.
We recommend that you update your console as soon as your production schedule allows.
Thanks much!
Sarah
