We have installed a ColorSource 40 console at a town hall venue that is showing some weird behavior whenever releasing a playback that has a single cue recorded:
- Select circuit of some arbitrary RGBW lamp (e.g. tested with Robe ParFect 100 running Mode 1)
- Put intensity to full level, select a deep blue color
- Record to a playback
When moving the playback fader up, the color fades as expected, however when moving back down, the lamp switches to full red output for a brief second before switching of. This can be seen as a red flash on stage.
What I know so far:
- RGBW channels of fixture all have home value of 255 (R255, G255, B255, W255)
- When moving the playback back down, red jumps from 0 to 255, fixture does not return to home position but stays at (R255, G0, B0, W0)
- This can be observed both by monitoring the DMX output via 3rdparty gear or by checking the 'universe' view on the patch screen
- Software was already upgraded to 1.2.0 including 1.1 bootloader
- Also tried with a manually written fixture and different lamp type, can observe same behavior
Any ideas what might be going wrong there? Please find the show file attached: /cfs-file/__key/communityserver-discussions-components-files/164/cabarett-training.zip
