CUE update impossible, without some strange transition
COLORSOURCE 20 AV V1.1.2 (8/2017)
Very easy case ! If you modify a CUE with the circuit and store it into this CUE though the "Live Cue edit" , this CUE is NOT reload (with new modifications), so that on next transition you cannot clear modified circuits without affecting the live. I have made several test to workaround this problem, I do not find any solution to modify a Cue in LIVE mode, store it, and continue the show properly. If some has found a solution or better a software update.... Thanks
  • Finaly I found a workaround . I have to UNCHECK the box "auto select with fader" in the setting menu. So I can load a CUE, select channels I want to modify, move up or down the touch fader on the screen, record/edit -> live edit-> Yes.
    AND NOT FORGET to unselect all channels. I works, but the only thing, is when you load the next step, it load briefly the "OLD" memory (during the transition).
