Profiles for Monoprice Stage Right Lights?
Our theater has just purchased a CS20 and are going to be dipping our toes into the LED color changing waters.  We've started with 3 different fixtures from Monoprice.  All three are labeled Stage Right, I don't see where these listed in the fixture library (posted elsewhere in this forum).  Can I get profiles for the following fixtures so that we can get them up and running when they arrive?
Stage Right 3-Color LED Light Bar- 612601 - 26 Channel Mode
Stage Right Super-Bright, 12-watt x 7 LED PAR Stage Light (RGBAW-UV) - 612745 - 11 Channel Mode
Stage Right SoftStage 80W COB LED Stage PAR (RGB with 30° and 80° Lens) - 612768 - 8 Channel Mode
Thanks in advance.
  • Hello, please read the documentation, and will found inside that for special fixtures, there is a specific software to create your profile. Go to the download page and choose ETC_CS_Personality_Editor_1.1.1.9.0.4.exe
  • I see this is done for other lights posted else where in this forum, I hope the same can be done for these fixtures. As someone who is not versed in creating a fixture from scratch I think the professionals at ETC would be better suited for the task.
  • Hello,
    I'm not sure that this is the job of ETC staff, and I thank them for having proposed a software so simple to access for this task. Too bad it only works under PC.
    Try it, it's extremely easy to do, you probably have all the info for these lights, it's usually the most complicated.
  • For exemple, see attachment, for the Stage Right Super-Bright, 12-watt x 7 LED, it takes me less than 10minutes to do the 11 ch mode. Edit them to show how it looks. You have to rename the file userlib.jlib (do to file transfert) and put it on a USB key to be recognized by the CS20. Good luck
        "date": "2017-10-26T07:12:39Z",
        "editorVersion": "1.1.1.9.0.4",
        "personalities": [
                "colortable": "EDDEAC65-BD2E-4D87-B163-D7A2434EC081",
                "dcid": "223F72D7-E901-4CAB-AB75-470AEAFDA989",
                "hasIntensity": true,
                "manufacturerName": "SUPER BRIGHT",
                "maxOffset": 9,
                "modeName": "8ch",
                "modelName": "12x7W RGBAW UV",
                "parameters": [
                        "coarse": 1,
                        "fadeWithIntensity": false,
                        "highlight": 65535,
                        "home": 65535,
                        "invert": false,
                        "name": "Red",
                        "size": 8,
                        "snap": false,
                        "type": 5
                        "coarse": 4,
                        "highlight": 65535,
                        "home": 65535,
                        "invert": false,
                        "name": "Amber",
                        "size": 8,
                        "snap": false,
                        "type": 5
                        "coarse": 2,
                        "highlight": 65535,
                        "home": 65535,
                        "invert": false,
                        "name": "Green",
                        "size": 8,
                        "snap": false,
                        "type": 5
                        "coarse": 3,
                        "highlight": 65535,
                        "home": 65535,
                        "invert": false,
                        "name": "Blue",
                        "size": 8,
                        "snap": false,
                        "type": 5
                        "coarse": 6,
                        "highlight": 0,
                        "home": 0,
                        "invert": false,
                        "name": "UV",
                        "size": 8,
                        "snap": false,
                        "type": 5
                        "coarse": 5,
                        "highlight": 65535,
                        "home": 65535,
                        "invert": false,
                        "name": "White",
                        "size": 8,
                        "snap": false,
                        "type": 5
                        "coarse": 0,
                        "highlight": 65535,
                        "home": 0,
                        "invert": false,
                        "name": "Intensity",
                        "size": 8,
                        "snap": false,
                        "type": 1
                        "coarse": 7,
                        "highlight": 0,
                        "home": 0,
                        "invert": false,
                        "name": "Strobe",
                        "ranges": [
                                "begin": 0,
                                "default": 0,
                                "end": 14,
                                "label": " \nNote used"
                                "begin": 15,
                                "default": 15,
                                "end": 255,
                                "label": "Strobe (fast-slow)"
                        "size": 8,
                        "snap": false,
                        "type": 4
                        "coarse": 8,
                        "highlight": 0,
                        "home": 0,
                        "invert": false,
                        "name": "MACRO",
                        "ranges": [
                                "begin": 0,
                                "default": 0,
                                "end": 31,
                                "label": "Not used"
                                "begin": 32,
                                "default": 32,
                                "end": 64,
                                "label": "dark bright"
                                "begin": 65,
                                "default": 65,
                                "end": 95,
                                "label": "bright dark"
                                "begin": 96,
                                "default": 96,
                                "end": 127,
                                "label": "Dark-bright-dark"
                                "begin": 128,
                                "default": 128,
                                "end": 159,
                                "label": "Fade"
                                "begin": 160,
                                "default": 160,
                                "end": 191,
                                "label": " \nDark-bright-dark (auto run)"
                                "begin": 192,
                                "default": 192,
                                "end": 223,
                                "label": "Color flash change"
                                "begin": 224,
                                "default": 224,
                                "end": 255,
                                "label": "Sound activated"
                        "size": 8,
                        "snap": false,
                        "type": 4
                        "coarse": 9,
                        "highlight": 0,
                        "home": 0,
                        "invert": false,
                        "name": "SPEED",
                        "size": 8,
                        "snap": false,
                        "type": 4
  • ColorSource fixture library updates are posted on the product page here:
    http://www.etcconnect.com/Products/Lighting-Fixtures/ColorSource/Software.aspx
    In order to create fixtures personalities, ETC need a copy of the manual for the fixture.
    In some cases the name in the manual is not quite the same as that written on the fixture, unfortunately this is particularly common with cheaper LED fixtures.
    I suspect that the first two fixtures are already in the library as:
    • Monoprice: 3 Color LED Light Bar
      (Note: This is not the same as the Monoprice: 3 Color LED Bar Light)
    • Monoprice: Par Stagelight RGBAW-UV
    If these are not the right fixtures, please provide a copy of the manuals so ETC can add them to the fixture library.
    Unfortunately we can't help without a copy of the manual, as there are so many fixtures and manufacturers with very similar names that it is almost certain that we'd use the wrong information.
    Assuming it is the "3 Color LED Light Bar", mode "H" (26 channels) is a "multi-cell" mode, which Eos and ColorSource don't currently support.
    If you want individual control of the cells, you would need to patch that fixture as several of the Generic: LED - RGB.
  • I’m looking for a profile for the Stage Right 80-Watt COB LED Stage PAR (RGB), I cant seem to find anything that will work. The link for the manual is below. Thanks
    downloads.monoprice.com/.../612768_Manual_161103.pdf
  • I believe the 6 channel mode is the same as the Monoprice Stage Right Par 64 Stage Light, which is in library 13.4.5, currently on the ETC website here:
    www.etcconnect.com/.../Software.aspx
    I've added the COB variant to the list.
