CS20AV So slow Monitor
Hi Everyone,
The monitor of my CS20 AV in external monitor mode is so slow and cant show some parts in time.
I cant work so in time if the monitor don`t shows all and not in time.
Greetings
  • Hi Lukas!
    It sounds like your monitor is either not compatible, or, more likely, your refresh rate is set too low on the monitor itself.
    HDMI-compliant monitors will either have a refresh rate setting (MHZ) or response time setting (Overdrive/Normal) on the monitor itself. Try playing with these to see if the issue resolves. Additionally, send me your showfile please, and I will use it on my systems to see if there might be something else going on.
    Sincerely;
    Brandon Merkle
  • Thank you for the video, Lukas!
    Did you have a chance to try the monitor settings I mentioned?
  • Also, if you have a moment, would you attach your showfile so I can have a look at that?
  • Yes I've tested the settings and tested it on two other monitors but there's the same problem. That's not always. Sometimes a reboot fix the problem but then it comes again.
    Best regards
    Lukas
  • Tomorrow in the evening I have time for that, yes. But I tested it also with another showfiles.
