I have a Colorsourse 20 console set in "Complete" mode and according to the documentation the 20 faders on the left can be set to channel or playback mode, how/where do I set it?
#1 - The faders don't seem to do anything, but if I go to keypad mode and select a channel, the button under that fader lights up. Via keypad mode I can set/change intensity but nothing with the fader. There is a Playback 1 defined in the show file, if I erase that will the faders default back to channel mode?
#2 - When I create a look and record it as a cue it appears to record, but when I play the cue back I get no output. I know I have DMX connectivity since I'm able to create the look to begin with, and the console acts like it's playing the cue (I see the fade times count off) but the look doesn't come up on stage.
