ETC CS20 - after pulling down (switching off) the playback fader and switching to manual mode the cue remains running
Hi there!
I have a problem with CS20.
I record a scene to a playback fader (doesn't matter which physical fader).
Then I return all fixtures to home position.
Then I go to playback mode and pull up the fader - the scenes run as should.
Then I pull down the fader with playback - the fixtures dim out but moving heads continue to move in dark.
I switch to channel mode, choose any fixture, move any fader up - but fader continues to function as a playback fader outputting the same data I recorded into the scene.
Then I open fixtures parameters from the screen - I see that data is the same as I recorded into the scene.
Then I once again press Home - the fixture returns to home position.
Then I pull the fader down completely.
Then I pull the fader up - only then the fixture starts to work in manual mode.
Please tell me what to do to switch off the playback completely before going to manual mode.
