Hello,
I noticed some interesting behavior when recording two effects into a cue this afternoon. I'm running v2.5.0.11 on a ColorSource 20. I unfortunately don't often have physical access to the console (today was a bit of a one-off), but have duplicated the behavior in the offline editor.
I have a show file with 8 ColorSource PARs. When recording two effects into a cue (I used "Aqua" and "Flicker"), only one of the effects seems to play back.
Steps to reproduce:
- Set 1 thru 8 @ full; Record cue 1
- Select 1 thru 8; add "Aqua" effect; add "Flicker" effect; Record cue 2
- Clear > All
- In cue list, go to cue 1
- Press go
- Observe that only the flicker effect is running.
I've recreated this in a bare show file in the offline editor here - https://1drv.ms/u/s!AvcCRDoCLMzmkqUi0IkUliEOre3HlA (Not sure if there's a better format to save ColorSource console show files? I'm used to swapping .esf files...)
