New versions in progress ?
Hello,
Is there no more new version going after the 2.5 ?
I do not see any beta version anymore !
Because I just made a show with version 2.5. There are still some blocking points.
- The effects (including colors) work poorly, often it is necessary to restart the console to achieve our goals.
- when you want to immobilize a projector by switching from one cue to the next, just select it: it's good. Except it works for intensity and color, but NOT for position and zoom.
- we are still waiting for a version of Personnality editor, since the current one has problems of color rendering (projector and selection button)
- when replacing a device with another device in the patch. Would there be a way to reset channels other than (pan tilt, color, zoom) in all CUEs?
  • And I will add:
    Some memories, with effects are impossible to change. The effects generator seems completely disturbed by any modification. And not work anymore, you have to clear, to reset ...but sometime no way...
    There are memories that do not memorize properly including and I noticed that it is with the blue color under a weak intensity, that it is quite unstable.
    You do not imagine the loss of time that it generates.
    I never had this before this 2.5 version.
  • Hi,
    There are certainly new versions coming up. We are almost ready with v2.6 for beta test. However, I am not sure all of your issues and requests are covered if we don't know about them since before or are able to reproduce. Trying to clarify some of the things you mention:
    - Effects poorly working: Can you give us more information about this?
    - Block position and zoom: This is currently not planned.
    - Personality editor: Is this really about the personality editor? This is about the selection button going black, right? This should be fixed in v2.6.
    - Replacing device: This is currently not planned.
    Regards,
    Anders
  • More comments: Could you give us an example where effects cannot be edited? We need to be able to reproduce this here to be able to fix it.
    Memories not memorizing: Is this about colors when you have used direct emitter colors? We have just fixed a problem in v2.6 where direct emitter colors misbehave, especially on low colors.
  • It is difficult to explain, In some Cue, I have an effect color and sometime an intensity effect, this on eight device.
    If I have to modify one position (pan tilt) from one device, the effect on this device is brocken. And the problem, is that, in this case, it is impossible create again the same effect one this cue, without to reset, to clear color....
    I can send you the project and give you the cue Nr.
    Memories not memorizing : good news if you detect the problem.
  • - Effects poorly working : is the problem we speak about just before. Effects can not be modified without to break it.
    -Personality editor: Is this really about the personality editor?  YES, you explain us, that all device made with this edition of PE, have problems with selection button color, AND color mixing.
    With these devices, when I choose a Blue color, with the pad window, there is always red into it. It is not possible to make a true blue without to use the direct emitter colors.
    I look forward to version 2.6, hoping that it will resolve some of these concerns.
  • Here is the show
    https://1drv.ms/u/s!AgAT9FIDC1tIjfBrU8Zj4cCV9idKOA
    Step15 :if we modify a device (pan tilt) of this sequence the effect is broken.
    step 26: normally the channel 28 should be blue at 8% and 30 at 8% white. I had difficulties memorizing this scene, it was never reproduced as planned.
    Step 72: Normally channel 27,28,29,30,38,39 have an color effect "primary" .But the channel 30  does not have the same intensity. Impossible to change without breaking everything.
  • Hi PBo67,
    As Anders mentioned, we are actively working on v.2.6 and hope to beta this soon.  We are working to write up both your issues and LysterJ's issues from another post and work to incorporate them into the next version of software.
    Seth Starr
    Acceptance Test Specialist
  • You mention various problems with editing and re-recording: Are you using "Update Live Cue" to re-record in this case? Or are you using some other method for editing?
  • On the
    Step 69.1 : Try to replace this poor effect (which is not the one planned) with a effect color FLAG on 27 to 30 and 73 to 40 and see !
  • All these recording examples seems to work for me and our tester. Are you using "Update Live Cue"?
    (recording of memories on low levels of direct emitter data is a separate problem that is fixed in v2.6)
  • Oh YES, Every time I use "Live update Cue".
    To try to workaround theses problems, I try to go to "CUE editing" and clear the memory, but no way....
  • Do you make you test with a real console, or with the off line software ?
    Because with the software, it seems working, but not on a real console.
  • NO ! Anders, it's not possible you do not see anything, I can not believe that !!!
    I just try to load it on the CS simulator, and for exemple, on  the Step 72 the channel 30 doesn't have the same intensity , WHY ? and how modify it , TRY ! IT IS NOT POSSiBLE.
    And on the same way , all Effects are complicated to edit.
  • There is a problem in v2.5 with low intensities of direct emitter data that we have talked about separately. This is fixed in v2.6. Running with v2.6, I can fix the intensity and use Update Live Cue to re-record it. After that, it will play back correctly. So this specific problem is already fixed with v2.6.
  • Ok thanks Anders, I understood the problem of low intensities, but in the example, the whole effect was at full, but only one channel (30) is weaker.  I would like to be sure that you have correctly identified the problem.
    if I understand well, I have to wait on the v2.6 .
