Hello, I have recently purchased the Colorsource AV 40. I have an instrument that is not in the library. I am including the DMX protocol with this message. Can someone please let me know how or where I can get it added to the library?
Thank you.
Thank you.
you could download the ColorSource Personality Editor (PC only) and create this fixture: www.etcconnect.com/.../DownloadAsset.aspx
Thanks - I only have a mac to work with....
You could try to find an equivalent that might be in the library using https://onyxfixturefinder.com/ although purple isn’t a common colour
Looking at the colors i'm convinced that's just bad translation. Yellow should be Amber and purple should be UV. This is just another IRGBWA+UV+S+Macro fixture
