Can you password protect the ColorSource 20 console? If so, what are the steps?
Yes you can password protect the console. However, this password protection is for that power cycle instance only. A power cycle (reboot) will clear the locked state, as it does on all current ETC desks.
To Lockout the Console, which prevents you from Recording/Editing, Changing Patch, performing showfile operations, or other settings:
Tap Setup > Settings:
Create an PIN-code:
Setup > Lock:
Enter Passcode:
Now Record and Settings are Disabled:
~Seth
Hi Seth,
Is there a way to lock down total console usage?
