How to controll a 3Ch Haze Fog Maschine?
Hi all.
I would like to patch and Controll my new Hazer/Fog Hybrid Maschine (Stariville HF900)
It uses 3 DMX Channels (Sorry found the Manual only in German) 417157_c_417157_v4_de_online.pdf
Ch1 0-255   -> 0-100% Haze Volume
Ch 2 0-255 -> 0-100% Fan Speed
Ch 3 switche form Haze to Fog Mode: 0-127= Haze / 128-255 = Fog Mode 100%
I tried the Independet Buttons i can only switch to one fixed value for e.g. Haze Volume. Would be nice to have it on a fader and change the values in the screen.
Would be also nice to have the flash button to switch the Ch3 (Fog)
Is there a possibility to get it like that?
Thanks a lot
Lukas
  • I would do 3 separate channels if I had the masters for it. So if your hazer is DMX 100 so patch three dimmers starting at output 100. Then control them as separate channels. Takes up some space but solve the problem.
  • Hi jolsson.!
    This is not my prefered workaround. Du to the philosophy of the Color Source Console, and the reason why I bought this one - only one Fader per controlled item - I hope there are also another solutions for my request.
    I only need a button on screen to adjust Fan and Fog ( like adjusting speed of gobos on moving heads)
    For the fog funktion Ch3 I could use the independent Button.
