Need to have COLORKEY Mover Miniwash Quad 4 RGBW moving head light added to library. Thank you.
In order to get this added to the fixture list, we will need to see a copy of the User Manual, preferably as a PDF. I wasn't able to find one on the Colorkey website (https://www.colorkeyled.com/product/mover-miniwash-quad-4/)
Lights have not arrived yet. Emailed the supplier to see if they can email a copy to me. If not, lights should be here in a couple days so will send then. Will let you know. BTW - thanks for the quick reply to my post.
Found it. Had to go to their support page. Strange. www.colorkeyled.com/.../Mover-Miniwash-QUAD-4-Manual.pdf
Thanks, I will send this along to our developers.
I'm not quite certain what to make of "orange" as an emitter color - probably Amber?
I thought both orange and UV were strange since this is an RGBW fixture. ETC already has profiles on our board for most if not all the other fixtures from that company, so hopefully who ever is creating the profile will have a clue on this.
In that case, when you've received the fixture, would you please let us know if it includes a manual that matches (or doesn't) the one on their website? At that point we can work with you to build a profile using ColorSource Edit.
Lights arrived. Manual doesn’t agree with what was online. Tried to upload pics from my phone but didn’t work. Will take manual to work in the morning and make pdf’s.
The personality editor v1.1 Quick Guide is here:
https://www.etcconnect.com/WorkArea/DownloadAsset.aspx?id=10737490177
In essence, the steps are:
Optional:
All that said, if you can send us the "real" manual by any means then we can do this for you, and once you're confident it actually matches the fixtures you own we can add that to the main library.
Is a personality editor for Mac on the to-do list?
Hope this comes thru ok. It is just the 2 pages with the two channel mode options (14 & 16). If you need more, let me know.ColorKey Mover Miniwash QUAD 4.pdf
Timeframe should be fine. Any chance I could get a screenshot of what it looks like in the editor? Tried to do it myself (first try ever) but didn’t get something right. Would like to see it done correctly. Want to learn this. Thanks
Just to clarify... Will you be adding a notification to this message string when the personality is added to the library or do I need to keep checking the library file "ColorSource Console v1.0.2 Library Contents List 12.2.1" (only one I see listed).
