Music busking
The CSAV desks have some great gizmos for busking but they are not always easy to apply.
Sound2Light could benefit from having the noise threshold a variable setting. The ‘Attack’ parameter is misnamed. It is more of a Delay or Sustain
Effects can be applied live but it would be better if they started at zero depth so you can bring them in smoothly. Some way to beat sync them would be good, preferably using Sound2Light.
Sequences with Tap Tempo require quite a lot of programming which there isn’t always time for. There may be some merit in being able to crib an effect and translate it into a sequence, which one can then edit to taste and apply Tap Tempo.
Parents
  • In spite of the preceding caveat, I have just come back from lighting a Beatles tribute gig and the Sound2Light was terrific. Two 8 way cheap RGB wall wash battens modified with bits of wide angle fresnel rear window stickers to fan the beams in 24 channel mode with subs to bring on in pairs of varying colour. Different sub pages to vary the effect colour. Whatever criticism I have of the description of what it does the algorithm is certainly effective on Beatles tribute music.
Reply
Children
No Data
