EOS to D3 MIDI trigger issue
We are using an EOS Ti (sv 2.5.0) to MIDI trigger a D3 media server (via Kiss Boxes and a Network Switch).  It works in every instance except for the one EOS cue which also happens to links to a macro.  If we hit the "Go" on the EOS for this cue , the D3 doesn't take the cue.  Strangely, if we then go to the previous cue and try hitting the "go" again to the macro-linked cue, the D3 will then take the cue this time.  Is there some conflict with MIDI and the macro?  I can move the macro to another EOS cue that doesn't have a corresponding D3 cue, but I'm hoping someone can explain this phenomemon, thank you!
