UDP "#" doesn't work when trying to change database field labels
<U1> $ patch #
then
<U1> $ clear_cmd Text1 label labeltexthere #
then
<U1> $ live #
_____
Expected result: Text1's field name is changed to labeltexthere
Actual result: Nothing happens. If I disable the "live" step (3), U1's command line is still waiting for an "enter" with the onscreen keyboard pulled up and doesn't seem to register the # at the end of the second string there
Have tried putting the text in quotes but that yields the same results. \r instead of # also yields the same result. Note that # works for me for literally everything else except this particular command.
Any ideas?
