qlab controlling eos nomad cue timing issue
I got qlab calling cues in nomad thanks to this forum. However,  when I call a cue out of order it snaps to the cue.  I have used midi with our old 250 board and I am used to calling cues out of order because it always uses the timing of the called cue. Without this I'll have to rethink this whole setup.   Can this be fixed?   FYI:  Using osc string. eos/cue/xx/fire  in qlab.  Maybe I should try direct midi instead?  Or a different string?
Thanks.
