I got a message to update my firmware, but I can't find the download anywhere on the site. I am running an Ion with the latest updates installed. Can someone point me to the proper place? Thanks!
the installer already put the respective firmware files on your harddrive, you just need to do the installation. to do that head to the shell, settings, maintenance and scroll to the bottom
Thank you for your response. My board is not connected to the internet - I do all my updates via USB stick.
that's very good! however this doesn't change anything. when you used your USB stick to install 2.8 not only the software 2.8 was installed but also the new firmware files copied. all you have to do install those firmware files into your system. and that's done in the shell, settings, maintenance, at the bottom
Aha! That is what I couldn't figure out - thank you so much!
