Hi there!
anyone knows if it’s possible to use the EOS “zoom”, “edge”, “pan”, etc keywords/softkeys on a OSC environment? If so, how?
thanks in advance
Hi there!
thanks in advance
Yes, it's possible, what do you want to do?
For example: [channel x] [zoom] [home]
You will find the description in the manual starting on page 531 in the manual.
You can download the manual on https://www.etcconnect.com/Products/Consoles/Eos-Family/Eos-Ti/Documentation.aspx
e.g. /eos/chan/x/param/zoom/home
You are absolutely right: need to read the manual more carefully. :)
Thank you!!
