I have a macro that runs our fog machine pump and fan and is programmed to turn the pump on and off at different intervals over a 6 minute period. is there a way to trigger the macro in a cue?
Sure. Try this syntax: [Cue]{Execute}{Macro}, then type the macro number and hit enter. Just make sure you use the softkey for {Macro}... not the hard [Macro] key.
Hope that helps,
~Paul
That is because the "key" macro is really 'Macro_Button' and not just 'macro' Where is the Macro_Button softkey in the Macro Editor???
No softkey, just use [Macro] when in the macro editor
