Hey fellow tech heads.
Quick question, I've taken over a show file that runs channelling starting from a zero, such as 100, 101, 103, instead of 101, 102, 103, 104.
I want to change it so numbering starts from 1.
Is there a way to replace a fixture globally on the ion? I know I can use blind and "copy to" or "recall from" to copy the values in cue lists and subs etc, but is there a way to replace a fixture entirely, so that macros, palettes, presets, groups, cues and all other plotting change with the replace command?
Sorry for the length! Help a brother out
Cheers
you can go to patch and use the move command. Chan 100 thru 103 MoveTo 101 Enter. you can get to MoveTo by pressing CopyTo twice.
there are two cases where your channel numbers will not follow: Macros and Magic Sheets. there is no way to accomplish that.
