Can a submaster on the Ion contain more than 1 cue? I'd like to program a timer sequence to automatically turn a hazer on and off. Can a sub hold a sequence?
As an alternative, I programmed an effect which worked for what I wanted, but I'd also like to make a momentary which I can use to haze on the fly if need be. With the Effect running on a sub, running the sub which has my hazer at full has no influence. I this a precedence/priority issue? With the effect running, the hazer at full sub has no influence on output. Thanks.
