2 RJ45 ports usage in ETC ELEMENT?
There are 2 RJ45 ports in ETC ELEMENT,in setup I Know the the first Ethernet (assuming IP is 10.101.1.97)is sending main signal pass thru switch to gateway , if I plug Ethernet 2 (Which is on the same switch as Ethernet 1) to second  RJ45 Port  (assuming IP is 10.101.1.98). Does it mean if the first Ethernet fail, the second Ethernet will take over the work of the fail one?
Vincent
2017.5.1
