Unsure if this has already been noted.
I have a cue 0.1 with channels at 0%. Channel X is not live until cue 10. In blind I select cues 5 thru 7 and recall channel X from Y, in which channel Y is live. Channels X value of zero and all cues prior to cue 5 is suddenly removed.
This only happens when channel Y is marked within the range of cues I'm trying to edit.
