I have an Ion running 2.4.0.9 and Nomad software running on my PC that is the same version. When I try to put the PC in mirror mode it will not see the master ION. I can ping the ION from the PC and when I look in the logs on the ION it lists the PC as a device it sees. When I click mirror mode it eventually just times out. I tried turning off the firewall in case it was some strange port problem. Interesting, I can not ping the PC from the Ion although the Ion does list the PC as a device it sees but just won't connect to it.
Any hints as to what to try next?
-Ed Hunter
