User modes versus Primary
Hi
I am often sitting in the auditorium using a nomad PC to a) control the rig & b) look at cues and channels etc. Using the Nomad is fine and I do like the relatively simple networking & user set up to make this happen.
I often assign myself a different number user so as not to interfere with the main console. Due to being a different user number,  I am getting frustrated at not being able to see the changes that the op has made. My user level/screen will not show the manual changes that they have done. Depending on the speed & number of changes required, I may end up asking the op what are the levels now at etc. Just looking to speed up my response times etc.
Is there a way to view the live/primary channel screen whilst the Nomad is set up as different user? I often do some of the plotting work/fixes at the same time the op is using the console. Being the same user is not practical etc.
I am sure there is a way to achieve this but I cannot seem to find the way.
My screen is normally set to Channel Flexi Active and Cue playback.
An RVI is not something that I will have access too.
Many thanks in advance.
Eamon
