Hi all,
since updating our ION with 2x 20 fader wing to version 2.6. there are a few things that I noticed, after loading my standard show file, and don't know if they are intended or if they are bugs!?
- my effect subs used to be configured in 2x. Fader 1 set as effect rate, bottom button as Start Stop Effect and top button as Off. Fader 2 set as effect size, bottom button as Start Stop effect and top button as Freeze. now since the update the bottom button is automatically set to Bump!? I do have a lot of effect subs so a bit of a pain to manually check and change them all.
- I have some macros to change manual times on the fly. they used to change all parameters but after the update only manual up time and down time. al the non intensity parameters are not changed!? the macros are all learned and edited and the syntax is a s follows: Clear_CMDline Blind Setup Enter Clear_CMDline Manual_Up_Time #Enter Clear_CMDline Manual_Down_Time#Enter Clear_CMDline Focus# Enter Clear_CMDline Colour# Enter Clear_CMDline BeamEnter Clear_CMDline Live Clear_CMDline Enter After relearning the macros the commands changed for the non intensity parameters as well to Manual_PARAMETER_Time. it seems that something went wrong in the file transfer from version2.5 to 2.6
- another issue that seemed to have resolved itself after a few re-starts was that intensity effects would load but not run when started after GO To Cue Out Enter was performed. I had to bring the relevant channels up first and then could take them out or sneak out and then the effects would run. this has resolved itself somehow???
thanks a lot everyone! by the way I absolutely love the pop up windows!
