Dimmer Curve Park
I am running a show with 7 Chauvet HexPar12 and 7 Chauvet Tri Tour.  I have the dimmer Curve on my ETC GIO set to Linear on both fixtures and that is what I want them to stay at.  But, I have around 40 different Cue Lists that I use depending on the week and when I run through those lists it changes the Dimmer Curves back to "From Menu" which puts them all at different curves which looks terrible.  Is there a way to park the dimmer curve on these fixtures or set them to where they won't change as I run through the different cue lists?  The fixtures are not in a place where I can access them easily, and I don't want to have to go through every cue in every cue list and update it.  Please Help...
