Hello there ,
I need some help for this Robert Juliet 340LF . Unfortunately this fixture is not available in ETC fixtures library.
I try to use GENERIC (16 Bits Dimmer) to control the light. But i found out the dimmer curve is not smooth although I had set the dimmer curve smooth to LINEAR at the fixture itself. There will be jerky when there is a change of intensity from CUE to CUE.
It will be great if you guys can advise regarding this problem.
Thank You.
