When using the pixel map editor it can become very difficult to tell fixtures apart. Although it is easy to tell types apart and the type show up when selected, there's no way to see the address/channel of that fixture or what direction the pixels are set up.
I feel an easy way to fix this is to have the bottom edit pane change to that fixture. I've attached photos showing how it doesn't update to reflect the selection.
You can see when the selection is updated the fixture type is updated, but the information such as channel, order, and direction do not.
Another helpful way of identification would be to toggle the fixture #, address/channel, and direction arrows on the chart itself on the fixtures, this would give a quick view and would greatly assist in quick identification and editing.
It would also be great if there was a way to add labels similar to the magic sheet.
I am really enjoying the pixel map feature, it has been a great way to add effects quicker than to slow program them.
Thank you
-Rhamkota
