color led on a sub
Record a simple rgb led fixture at full color blue to a sub. When I run the sub I want the color blue to fade on and off as intensity so I set it as intensity. However I also don't want the fixture to remain blue, even though it's at zero or the sub is down.
I use this for behind curtain scene set change lights. Curtains close. Sub up. Finished setting up the set scene. Sub down. Curtains open. Lighting cue up. The fixture is blue in the cue unless the bump is tapped to release it.
The sub is set for manual priority. I have tried P4 and some other priority settings but just can't get the sub to release when the fader is down.
Scratching my head.
