Since the new version (2.7.3) the command: "Chan (x) make absolute" gives me the error: Syntax error.
To work around the problem I have to type: Chan (x) AllNPs Make absolute.
Is this a bug or a new syntax?
cordially
cordially
I am not seeing this. I think I am following the same keystrokes...
For Example: [1 Color Palette 1 Enter], [1]{Make Absolute}[Enter] works.
Hello,
It's really on version 2.7.3. Before this command worked very well!
I join you a video to be sure I'm not crazy lol !!!
thank you
What language is your console set to?
that's french
i found the problem, it's in the french language file:
the softkey Make Abs in the french version tries to write "Conv._en_val_absolue", but the dot is not allowed. to make this work again, the translation file has to be changed...
Bug submitted: EOS-47931
