I would like a new flexi state. Channels above 0 intensity.
Not at a desk at the moment, but I think Flexi Active does this? Is there something different from Flexi Active you're looking for?
Flexi active shows new zero values. So does flexi in use.
I'm having to record two cues in a row as a workaround.
If you need to select all channels above zero you could do a query for this. You could even put this in a macro, to easily select your channels with a value above zero.
What else would be your usecase for seeing only those channels if I may ask so?
In a more static environment, where the history of a channel doesn't matter, or in an environment where you jump from cue to cue out of sequence.
In those cases e.g. green zero channels are not that important
I agree. I use Flexi Active all the time, and the 0's are completely unimportant to me, especially in the cue adjacent to my dimmer check cue!
