I’ve been happily cueing all morning and halfway through my designing I selected the scrollers to change color and the ML window no longer show the color picker. Is this an issue with the board or cable?
is the selection terminated (did you press enter after typing the channel number)?
can you post a picture of what you're seeing?
Yes. I’ve gone ahead and shut off the board and restarted it and it cleared up. Once I realized none of my LEDs were working right either I knew it had to be the board.
good call. if it happens again pull log files and contact support.
