How do I solo a channel. For example take 1 selected channel and momentarily black out everything else.
The easiest is to select the channel and hit enter, hit the [Rem Dim] button and hit enter again. That should black out everything except the channel(s) selected.
To restore the look you had before doing this, hit the [Rem Dim] button again before you hit anything else.
You can use the encoders to pan and tilt while in Rem Dim.
Note: Highlight as ueliriegg mentions above lets you do more and is more configurable.
Highlight is an amazing feature.
but if OP is looking to Solo a Submaster, you can set the Fader button to act as a Solo instead of the normal Bump function in the Fader Config Tab.
