What is the syntax to make a macro that will change the default sneak time?
I would just learn it. You can still clean it up afterwards. When running the macro remember that it has to run in foreground mode
Running in the foreground was the missing bit. Thanks.
i really wish it would work in the background, though.
sneak time is user setting. so the macro must be executed by this user number, which means you need foreground. background mode means the macro would run as user 0
Makes sense. Thanks
