Tech was pushing GO button to check every cue, why, I don't know. Then I remembered reading there was a key sequence that would run through every cue without fade in/out. (this is on the Element 2).. Couldn't find it in the book.
Thank you. Passing it on. Will save time and a lot of button presses.
Works with Stop/Back (the key above Go) too.
