Hi.
Where can we get new fixture profile for ION 1000 for the U King 60w mini.
60W LED Mini Moving Head Beam Lights DMX512 Stage Lighting Party DJ Light
It does both 11 & 13 channel setup.
We have tried and tried trying to build our own but no go.: (
Attached is a PDF of the manual they sent.
UKing60wattMiniLEDMover.pdf
Looks like we got the moving working but not yet able to turn on the light and adjust dimming yet?????aaargh.: )
Any help?And Thanks!!
can you make a screenshot of what you have so far?
Also, it does not show the 11th channel line but that says: White
Also, we tried setting brightness range to 0-255 as well but no go.But we are able to move it around fine now.: )
change Brightness to a parameter called Intens.
red, green, blue and white each should have a home value of 255
Will do.We tried Intens but it keeps putting it to the bottom???We will change the r/g/b/w to 255 home.
stay tuned.
it doesn't matter where in the list a parameter is listed. just get rid of brightness. if intens is at the bottom that's fine as well. go to Intens and in the DMX column enter 6.
and the first 4 parameters should be different as well:
delete Pan 2 and delete Tilt 2.
1 / Pan / 16b: 1,2 / 32768 / / -270 > 270
2 / Tilt / 16b: 3,4 / 32768 / / -120 > 120
it should look something like this:
remember, it's not important in which line something is listed, just that the horizontal information stays together
Done.Still no light.
Pan and title still working fine.
Just no light.: (Also, we are working in 11chan mode.Also, we noticed you have the pan running -270 > 270 but the manual says 0 -255 for everything?
Just trying to understand the numbers.: )Appreciate your help!!
when you change the personality, don't forget to press the green button "Save Fixture".
then go to Live, press GoToCue Out Enter, and check again
the thing with Pan and -270:
Eos helps you program the lights by allowing you to use Pan and Tilt in degrees rather than 0-255. i assume that the moving light has a pan range of 540° (like most moving lights nowadays have). 540° in total is the same as going from center 270° and 270° to the other side. that's what -270 > 270 says.
the advantage of this is that you can say something like "i want my light to turn 90°to the right": Chan 1 Pan +90 Enter
: (Still no light.
Movement still works, but no light, Intens set to 8b:6.
It shouldn't make a diff if we are in 11 or 13 chan mode right ?
Just pulling at straws here.
When you're in live, select the channel and press About. On the right hand side in CIA you see Patch. Click it. Can you post a screenshot?
will do. stay tuned...
I figured it out !!
Thank you ueliriegg !!!!
You got us there.
We are running 2.7.1 and weird things happen.
Once we rebooted, created a new profile exactly as you told us, even though the previous one was exact, everything works fine.
lol
Thanks for the help!
