I am having a problem with editing palettes on my Ion. Normally when I hit [palette][palette] it opens an editing screen that allows me to manually click on steps or other parameters. It was doing this properly ealier today, but randomly durring programing it no longer opens to that screen (specifically when trying to edit intensity palettes, but trying it with other palette types it does the same thing). After some messing around I found that if I select {edit} from the blind screen then the lighting designer can see the desired screen on the same user RFR, but it still doesn't show up for me. Any insight? Thank you~
