Editing Profiles
We are planning to use a Chauvet Swarm FX 4 (12). I found one quite easily and all the channels and in particular the User Ranges match nicely with the documentation.
Two questions (see picture);
When I look at the Parameter list two rows (Color Index and Color Index 2) are gray rather than bright white - why is this? And
Is it possible to change the parameter names to something more intuitive to see when we in the ML Panel when we select in live?
For example row 1; "Color Index" would make mores sense if we could label it like the manual. In this case ""Moonflower 1 Control" The same for all the other rows. Or are we constrained by what is in the drop down list? I'm trying to make the operation as straight forward as possible so the operator has a better idea what they are controlling.
