CD80 dimmer pack with MicroVision
I'm trying to connect an old analogue CD80 dimmer pack to my MicroVision FX for a show in a converted garage. The manual says it's possible to convert the 4pin output to do this and I have the capability to solder the right connections. What do I do? Anyone have suggestions for resources on this?
  • From the mind of Mr. David North:
    Depending on when the CD-80 was made, it might use a 4-pin XLR, in which case the cable is 1-1.  However, if it is an older CD-80 pack, with a TA4, then you need the following:
    XLR Pin
    TA4 Pin
    Signal
    Belden 9723
    Belden 9156
    4
    1
    Clock -
    Green
    Black
    2
    3
    Clock+
    White
    White
    1
    2
    Common
    Black
    Black
    3
    4
    Analog
    Red
    Red
    Found here:  http://www.pathwayconnect.com/content/view/92/26/
    But if your CD-80 pack is analog, as in 0-10vdc, then you need an analog output card [36-pin Centronics on rear panel]
  • As an FYI, ETC also offers a 4-pin AMX XLR upgrade for the MicoVision FX. You can contact your local dealer for pricing. (Part # 4030K4005)
    The upgrade needs to be done at ETC
