Acclaim 300 series restore factory settings?
I recently found myself in front of an Acclaim 300 that won't communicate with the dimmer rack. I temporarily replaced the board with a small loaner and was able to fire the dimmer racks, so I believe the board is defective. Before investing in servicing this board, I thought I would try a complete reset. Does anyone know of a command that will completely restore factory defaults? Or a special key sequence during power-up?
I thought I might also check the DMX output with a meter, see if it's sending anything, but I don't what to expect as I''ve never done DMX diagnostics.
Any thoughts would be appreciated, none of the installer contacts are in business.
Matt
Parents
No Data
Reply Children
No Data
