Multiple STACK sequences
I have a 2496 console. I use a stack sequence every Sunday at our regular church service. I want to record a separate stack sequence for a Christmas program, while keeping the other one. Can I record separate stack sequences and play them back individually?
It seems like the only option is to ERASE AND MAKE NEW or APPEND TO EXISTING
Thanks Paul
  • The best option is usually to have copies of all shows on an SD memory card.
    It's been awhile since I used a SF console, but you might not have 'Save' & 'Load' options without a card mounted in the console. You can use almost any card as the files are very small.
    You might also look into SmartSoft, the off-line editor you can use on a home computer.
