Accessing Stack Steps via MIDI
Is there a way to access the incremental steps (ex. X.1, X.2) of the stack via MIDI, or can only the "major" steps (ex. 1.0, 2.0) be triggered with Program Change 1-99?
  • I found the answer for anyone who may be wondering: Program Change 1-99 accesses the particular point in the stack. It's not tied to the actual number of the item in the stack. I.E. if your first 4 steps are 0.1, 0.2, 1, 1.1, then Program Change 4 will trigger 1.1.
    Out of this, I assume anything past the 99th entry in your stack is inaccessible via MIDI.
